penn slammer 260 reel
gazza2007au
im looking to buy the penn slammer 260 reel and im being told it does not have a really good drag system like the larger penn slammer range can someone tell me if this is true?
dingbat
Re: penn slammer 260 reel
It is not true.
The 260 and the 360 use the exact same drag configuration using HT-100 washers. The 260 would have a better drag than the 360 because of the lighter line rating. The 460 and 560 use the same configuration but use a larger drag washer as you would expect.
I use my 260 to jig Stripers. The reel has caught fish up to #40 without a problem.
HondaPower
My son runs a 360 slammer and the drag is very smooth, and has enough power to handle stripers up to 15-20 lbs if played well.
