I have a volvo penta 270 outdrive, with the electric motor drive lift.
Anyhow, just recently the motor won't lift the outdrive up, unless you manually reach under the outdrive and release the spring loaded locking mechanism first, then it works fine, until you bring it down all the way and it locks again.
If it helps, it stopped unlocking itself after accidentally hitting the throttle with the drive lift up, causing the drive to drop by itself.
Any suggestions???
Thanks guys
Any suggestions???
Thanks guys
