loco
- Apr 25, 2010
- 154
Long story short: we think the timing was off which has lead to pre-ignition and a plug melting. The core of the spark plug is missing, and now we have zero compression in that cylinder, so we suspect a damaged or broken valve and need to take the head off to see where we go from here.
Craning the boat out the water is seriously expensive, and we don't know how long it will take to get the head fixed or the block, if it's that that is damaged, but we do have the option of a drying pad, which is free (as the tide goes out, we can sit the boat on a pad for a few hours to work on it). The pad is 20m from the mooring, so my plan was to go to the pad, plug the inlet hoses for the sea water and exhaust, then tow the boat back to its mooring. Once we've fixed the head, we can do the reverse.
The engine's an AQ205, so has a big seawater pump with an inlet hose (easy to plug), but what about the exhaust? Can I just take the exhaust mainfolds off and plug them too? Anything else I need to consider?
As always, many thanks in advance for your help.
