I usually use guicksilver 2-stroke Ob oil in my 98' Merc 25hp and mix it to 50:1....or if money is tight, I will use the good ole' Supertech oil at wally world...and can never really tell a huge difference in the two. Yesterday I went fishing and forgot that I needed gas so I swung into the gas station to fill up the boat. The only oil that had on hand was Penzoil Outdoors 2-stroke oil. says TWC lll certified (I think that the correct letters) as well as TWC l and ll. Says prevents piston scuffing, ring sticking, burns cleaner and smokeless. So I filled up and mixed it 50:1 and went fishing. After running I have to say I am not impressed. First off it smells like burned wood when it's running (smells like ashes), seems like the motor did'nt run as well as it used to. I put Brand new plugs in it yesterday before the trip, and today I took them out and they were dry...not with the light oil film they usually have. Did a compression test and it's fine at 130psi even on both cylinders. Am I just overly concerned? Or should I dump the gas oil mix and start over? Anyone else use this oil before?
