Re: Pergola
If you have a little more info on it it would help with some feedback.
What will the pergola be used for? Grape vines? Open top & decorative with some top/side lattice? Outside patio seating area?
The support beam does not need to be that big to support open/decorative rafters. If it was me I would go with either a 2x8 (mininimum) or a 2x10 (maximum-preferred) and double it up. I would screw the two support beams together every foot. More importantly, when doubled up aside from the strength advantage, its a lot more stable to mount rafters on at the end connections and it sits on the vertical (4x4) corner beams with almost a perfect width fit.
Anyways, if it is decorative only you might want to look at getting/using cedar for the rafters and stain them....much better looking.
If you get really lucky and find a nice 4x8 cedar beam that would make a great 20' for the support beam.
The trickier part whethers it fir, cedar or whatever is going to be to find a 20'er. This length might be a special order.
My two bits.
BP
