Perko switch on Aluminum Boat
thakang67
Hello to all, My question is where do I mount my Common ground stud for two batteries and my distribution panel?
Thanks for any suggestions!
alldodge
I would suggest a battery buss bar, and keep the ground from making contact with the boat hull.
Ayuh,.... The motor's block is the common ground,....
GA_Boater
thakang67
Okay thank you I will go buy a bus bar a install it. I would like to install it back where the motor is. Is it okay to mount it on the wood transom?
thakang67
Bondo, so the way I understand what your saying is to run an sufficient cable to a ground on the block of the motor then to a bus bar mounted wherever then connect my batteries to the negative bus?
GA_Boater
YW. A buss bar can be mounted anywhere convenient. The mount screws/bolts are insulated from the wiring studs.
sam am I
Using the transom mounting bolts is the same as bolting the ground to the hull, a no-no in an aluminum boat.
His hull by default should already be grounded/bolted to batt neg through bonding wires. My stock Merc would ground my hull via two very specific factory bolted on bonding wires that intentionally bond/ground (batt neg) the transom mounting plate/bolts. If my hull was alum. that is........
However, running current through the hull or any metals that are grounded via bonding such as transom/mounting bolts, etc. as mentioned above (or even the bonding wire/s itself) is a no no.
See post #2, SilverTip is correct in his assertion
http://forums.iboats.com/forum/boat-...-aluminum-hull
