Permanent magnet gear reduction starter...
Lou C
Click image for larger version  Name:	PMGR Arco installed.jpg Views:	1 Size:	189.7 KB ID:	10860169
Ayuh,...... No doubt Lou,...... I've been usin' 'em for 'bout 5 years or so now,.......
Life is much easier changin' 'em,......
Lou C
Question:
any idea why they include that foam gasket? I installed it but at the same time, can't really see a good reason for it!
NFC....... not all come with a foam gasket, and if your trying to seal the flywheel housing, the sheet metal cover has a drain hole on the bottom....
nola mike
Question:
Ha ha Lou C , I just asked you this same question on another thead as I just got a PMGR starter for my swap.
Lou C
I had called the tech line at ARCO asking if you should fab up a front mount for these starters (he said not necessary) I should have asked about the foam gasket, lol.
