Misterbulbous
- Jul 12, 2018
- 47
Looking for some thoughts on two issues I’m having with my 5.0 carbureted GL-B.
1. Temperature sender in thermostat housing is alarming out before and after changing the thermostat and impeller. This is second summer with problem. Temperature at dash panel shows no signs of overtemp (slowly rises and stabilizes at 170). I don’t assume it’s the sender because I think it’s truly running hot. The cooling water is definitely reaching the thermostat and risers, but the intake manifold, thermostat housing and “large” hose exiting housing is very hot.
This is brings up 2nd problem - which seems to be vaporlock from the hot conditions.
My question...assuming raw water pump is good, thermostat is good, sender is good, is there another reason the temp would be high?
Generally speaking, the engine is in excellent condition. Always winterized, never stored outside, well maintained. But...the issue above has sustained for two seasons now.
Thoughts?
Thoughts?
