perspex
ididit
Hi can anyone tell me how to cut and drill perspex as I am making a new winscreen Thanks
tashasdaddy
Re: perspex
i believe it is basically the same as lexan, a very sharp drill bit, and very little pressure.
Re: perspex
About Any Sheet Plastics can be worked using Woodworking Tools..........
Just use Sharp Fine Toothed Saws,+ Go Slow.......
Same for Drilling,....... Sharp Tools,+ Go Slow......
CalicoKid
Re: perspex
And don't try it in the cold... The warmer the better, less likely to get cracks.
kenmyfam
Re: perspex
As above but put masking tape on both sides before cutting or drilling. It gives a much cleaner finish. Just peel it off when done.
Lexan is much easier to work with though.
Good Luck and let us all know how you go on.
