I have a 1986 Sea Ray Seville with a 3.0 140HP Mercruiser engine.
I'm in the process of replacing the points with the Pertronix Ignitor and new coil. The coil requires a ballast resistor, which the engine alreadey has a resister wire. The Pertronix requiers a full 12 volts. The instructions for Pertonix says to connect the positive wire to the ignition switch. This is where I'm a little confused. Do I have to run a wire from the Ignitor all the way up so the ignition switch where I turn the key, or can I connect the Ignitor up to the positive side of the battery, or the larger red wire connected to the starter.
I appreciate any help that I can get.
Thank you.
Thank you.
