I have an '83 Mercruiser 140 that I have recently switched from points to electronic ignition (Pertronix II ignitor and Flamethower II coil). After 30 to 40 minutes running very smoothly, the engine sputters and stalls. Checking voltage shows that I'm losing current from module to plug. Wires are good. I suspect a faulty module. Is it possible that module is failing after certain temperature is reached? Thanks,
