petcocks clogged
merc8978
1990 merc 4.3l w/alpha 1
petcocks not draining - removed and tried a wire to clean with no success.
When reaming out with wire it is hitting something hard like metal preventing the wire from sticking in more than 1/2" +/-.
Gary H NC
Re: petcocks clogged
It may be just so much rust.Remove the part that threads into the block and try the wire again.
Ayuh,... A Couple inches, yes.. I use a deckscrew....
45Auto
You have to remove the little threaded T-handle completely. It screws right out and is about an inch long. It has a 90 degree hole in the end. You can't get a wire straight through it.
The piece that's threaded into the block has a hole in line with the threads. This hole is what gets clogged. With the T-handle out, you can run a wire or nail straight through the piece in the block to un-clog it.
wire2
A 3/16" drill bit on a cordless drill is quick & easy. Keep it straight to avoid damaging the threads in the brass adapter. It takes very little pressure to drill into the rust. The resultant water flow will carry out most of the rust residue.
merc8978
I have a 2 peice straight petcock = no t-handle but looks like a nail is next
merc8978
I tried drilling but I hit something solid about 1 inch deep on both sides - Still only a slow slow drip. Is there a straight shot into block or some sort of metal plate that i am hitting or is that solid rust?
Donno,... Pull All of the pieces of the drain fittings,+ See what's up...
There is approximately 1" of cooling jacket between the outer, 'n inner walls of the block...
dingdongs
if the're the older petcocks its best to remove them completely as they only have a couple of small holes which go out sideways.if you drill them they will be no good.once removed you will see how they work and you may have some rusty sedement stopping water from getting into the small holes.you may find this type on the side of the block and maybe on riser too.do not be too heavy handed on the pressed steel t piece as its not hard to mess it up.
merc8978
ok then i am hitting the inner wall and still plugged up. All peices of petcock are removed.
How to clear out between inner and outer jacket?
6meter
The problem is that the rust isn't just near the drain hole, it's all over the motor. The right thing to do would be to remove the heads and pressure wash down all the water jackets. Not fun but no other way to completely get the crude out.
merc8978
Re: petcocks clogged solved
ok I got her flowing - for those in same situation :
you need to put a 90 deg. bend on stiff wire as I could not clear going straight in.
Put the doglegged wire into hole and ream left and right to get between cooling jackets.
Ayuh,... A small allen wrench works nicely too....
