Re: Philips head bolt next to drain plug question
Unless you are re-building the lower unit, NEVER EVER touch that screw!!!
I have done a couple of these, and the hardest part to get back in, is that darn screw, it took me over an hour this evening to get this bugger back in!, there is only one way it will go in, and if you don't get it right, you will know it..because the shift fork won't move the dog, then they just float around in the housing until they jam up and make everything really bad!
Straight head screw to drain, straight head screw for vent, staight head screws holding the split case together, Phillips head screw....Big no, no!
Carlos,
You should be able to tell by shifting your motor, even with out running it, if it went right back in as it came out, you might have got lucky and it didn't drop or shift out of place, but I would make sure and have someone shift the motor while listening to the lower unit before I took it out, as I said, you can hear it shift when moving the gear shift lever..
