Pic Quize Of The Day-
Boss Hawg
1st to tell me what this is & why water comes out of the unthreaded hole in center at times wins my admiration & thanks!:watermelon:
1992 Mariner 60HP
wired247
Re: Pic Quize Of The Day-
Its your thermostat cover and it sounds like your diaphragm might have a hole in it.
wired247
You need to pull up a exploded drawing of your engine or look through the manual. Those motors have like 7 or 8 parts inside the housing ie springs, poppets, plungers, diaphragms etc.. Its not a one piece deal. More than likely its your diaphragm that is leaking. Not so much a sign that the thermostat is going bad but it is a sign that the diaphragm is bad.
Boss Hawg
VERY usefull info- THANKS-
java230
replace the diaphragm, most likely everything inside is fine.
