PICS attached, is this normal? Water coming out from different parts of lower unit.
jpaulson
Just bought this boat. Its a 1995 Force 120 on a 1995 Bayliner Capri 1700 LS. When running it with the earmuffs on in the driveway, I noticed water come out of these three areas of the lower unit (see the three pics) The area where the water is coming from is circled in red.
Before I purchased, I sampled the gear oil in the lower unit, didnt appear to have water. Checked compression, 120 in all cylinders, I didnt start it up with a hose because it was in storage and didnt have access to a water supply so I did take a bit of a risk.
Please tell me water is supposed to be coming from these areas! After running it for a short while, I did notice a constant stream coming from the tell tale which is good, just want to make sure its ready for the summer!
Nordin
Re: PICS attached, is this normal? Water coming out from different parts of lower un
Just normal, nothing wrong.
#1 Gearshiftrod. The seal is inside the lowerpart.
#2 Exhaust through the prop. Most coolingwater exit this way.
#3 Water intake. Yes water may come out there when you use muffs.
Most importent for your checking in the water is the tell tale "pisser".
jpaulson
Shew!!!!! Thank you so much, I will sleep good tonight...
BoatingCop
#3 is not a water intake, but rather a place where exhaust and water, that has already traveled through the cooling system, exits. All completely normal and is functioning properly.
