Just showing the pic to this question that some of you asked, put the housing back on quick just to show how it kinda came off. the tube was frozen to the plastic peice on the water pump housing. did get it out but after it came with the lower unit. TH.
Tuning up and fixing up an old 1984 chrysler 115. The lower unit was not serviced in a long time im guessing 4 years. I struggled but got the lower unit off the Int. housing and came across 2 problems...
1. the water tube was frozen to the plastic peice on the water pump, and completly came out with the lower unit/water pump. do i have to take the entire bottom block off to get at this and fix it?
2. the sealing ring, spacer, and ruber collar did not fall out with the driveshaft, I looked up there and it doesnt look like I can get at it unless i should shove something up there to try and know it loose or something like that.
