Picture of my prop - what’s going on here?
nicholaseb
I purchased a boat with a mercury 90hp outboard this year. Took off prop to examine during winterization and saw the plastic piece inside all cracked and such. This picture is showing the back of the prop. What is this, do I need to replace, and Can I replace just the plastic piece? Thank you 4059278F-2E89-4AB3-91E7-FFED2103D33C.jpeg
ONERCBOATER!
Would like to see whole prop in picture just cause I'm curious as to possible damage. That said I have had sleeve/hub fails due to age and I imagine the Mojave sun and summer temps not great for them either.
QBhoy
Likely as a result of a bottom strike…and to be honest, I’ve never seen one of these sacrifice themselves yet, in person…but must admit, it looks a little strange to me. Firstly, the hub kit normally sits closer to flush to the edge of the prop…secondly, it looks like the actual prop edge has been damaged too. That’s a little strange. Wonder if someone has had a go at trying to pry that out, after it being stuck in. Would explain it being creased over and the damage to the edge.
Chris1956
Normally Mercury prop hubs have longer splines set nearly all the way to the base of the prop. That hub looks more like a Johnnyrude one. Johnnyrude splines are shorter in length, so they do not go toward the gearcase as far.
I would tap it out of the prop housing and see if you can find a number on it.
Scott06
The newer flo torq hubs have only a short brass splined section that clocks the propshaft to the plastic hub.
airshot
The area around the sleeve appears to be out of round, just me or do others that ?? Mabey just tired old eyes..
jimmbo
Likely just a Distortion from the Camera/Lens/Perspective, even Post Processing of the Image.
Yegboats
Like others have said these are desinged to break on impact so the prop spins free from the propshaft to decrease the likelihood of a bent prop shaft. If your prop isnt damaged I agree that ot almost looks like someone tried to pry yours out.
You can replace just the delrin prop sleeve. Buy it from iboats.
Faztbullet
Wrong thrust washer and incorrect torque will cause this as stated earlier
Grub54891
I’ve had many props off at the shop, with that type of sleeve. The only ones I’ve seen broke are ones that hit something. One of my own did that when I was out on Lake Superior, heard a thump and the wheel jumped a bit, checked the prop and it was fine. Must have bumped a deadhead or the like. At home that’s what I found, the sleeve was broke even though I finished my day without issue.
walleyehed
Looks to me like 2 things are possible. 1, Not tightened to the 40-50 ft-lb range or 2, it done exactly what it was made to do and gave out, possibly just above idle and although the prop isn't torn up, the hub has shifted. Rubex hub will fix any issues that plastic has.
