pictures of throttle linkage on johnson 25
FAC
i would like some pictures of the throttle linkage on a 25 hp johnson from somewhere around 1981 (that is the year of my motor) so i can compare them to my throttle setup hopefully i can get some pictures of the linkage that connects the timing advance to the carb linkage on the port side of the motor and also a shot of the front of the motor
thanks
Forrest
psteurer
Re: pictures of throttle linkage on johnson 25
Someone might have some pictures they could send. But I would recommend that if you do not have one already, get an OEM manual for this motor which has those pictures. Your a describing one of the steps required in a link and sync process. In the long run, you will be better off going through all the steps described in the manual.
tashasdaddy
agree!!!! ^^^^^
FAC
i agree with you guys also but for my motor the cheapest i found an omc manual was 95$ at kencook.com so i resorted to trying to find pictures
blimp
You should be able to find one on ebay or a few other sites for less than $40. I got a friend with a '72 25hp, i'll ask him to snap a few pics this evening.
FAC
thanks Gary, i sent him an email, i hope he has what i need
blimp; that would be good if you can get me some pics
FAC
thanks ezeke but i just bought one
