striker1211
- Jul 10, 2013
- 43
Alrighty, I think I am all set for anything now... My question is, should I even worry about a hard switch for the accessories? I am going to take the faceplate from the radio and the fishfinder inside when I am not using them. My plan is to use the existing wiring for my old cassette deck that was already installed, and for the fish finder use the grounding block under the helm and run power off the front side of the IGN feed (not the switched side, want it to be on when key is out. "If the key is in you don't swim"). Is there any reason I should not use the IGN feed? Also, my boat does not have a fuse/breaker block anywhere, everything looks in-line. Should this be a concern? Thanks.
