pin hole
I have a 17 foot fiberglass boat with a screw holein the hull and need to fiberglass over it but don't know what's the best stuff to use. Anyone have any advice?
ryanr623
Re: pin hole
Did this just happen? If not you need to check for rotten wood. Where is the hole?
help
help
i have a fiberglass boat and it looks like someone scraped the hull on a rock or something and did a bad job patching it. the spot is in the midde of the hull and about a foot long and 6 linches wide and i want to redo it over so it looks better and give it more strength. could i just sand it down and use bondo or should i get some kind of fiberglass repair?
Ciera2450
Re: help
Re: help
Bondo generally doesn't work well on a boat. Especially under the waterline. How deep is the scratch? Do you plan to regelcoat overtop of the repair?
Woodonglass
Re: help
Re: help
Welcome to iBoats!!!
Take some pics!! Makes it a whole lot easier for us to help you.
My signature has a link for how to post em.
Cadwelder
Re: pin hole
Not saying we won't answer every question here, but did you try a seach on this, as there has been a ton of the same situations here recently.
Yacht Dr.
Re: help
Re: help
Thats a mighty big pinhole you have there....
Pics..
YD.
PS. from pinhole to 12"x6" is an understatement dont you think ?
