Pinging
ptomlin
New to boating,bought a 1999 larson with a 5.0 ltr volvo penta which was running fine.Received a 4 blade prop with it and wanted to see the difference but when we go 3/4 throtle it seems to ping from the engine.Would the prop cause this of should i be running a higher grade fuel? It didnt do this with the 3 blade prop.I will switch it back and try it tonight to make sure.
rbh
Re: Pinging
if you are running higher RPMs it could be you are to advanced, check your timing?
rob
Re: Pinging
Ayuh,... What's the Pitch of these props,..??
Re: Pinging
Ayuh,... It's stamped on the props somewhere,... Along the side,..?? Under the Nut,..??
ptomlin
Re: Pinging
Weathers been rotten since yesterday so I havent tried the three blade yet
Re: Pinging
The 4 blade which had the ping is a 18,the three blade is an 19.
Ayuh,... It Ain't the prop,... It's the Motor....
At the very Least,... Change the Fuel Filters....
Better Yet,...
Have the entire driveline Tuned Up,+ given a Full Service....
