This is kind of a continuation from a previous post about the 2.3 locked up. I was able to pull the pinion bearing assembly out of the upper drive casing. Will the gear and bearings have to be pressed out and new bearings pressed on. It is a 1989 2.3 Cobra outdrive. Thank you and thanks to the help I received thus far from the folks at sterndrive.com
