Pinstripe is not coming off... Help please!
chrisf695
The pinstripe is 23 years old... comes off but the adhesive seems like its burned itself to to the gelcoat... goo gone, paint thinner is not doing it... used a heat gun for the top layer too... whats next? how do i get this off? Should i try compounding it off? I do need to do a full detail on the boat.
H20Rat
Re: Pinstripe is not coming off... Help please!
No other way, absolutely 3m wheel. Any decent auto parts store that has a paint department will have one. Just go slow and don't heat it up too much, you can burn some really hard-to-remove stains into gelcoat. If you see a hint of smoke, STOP.
3M also has woodgrain and sripe remover along with the woodgrain and stripe adhesive remover. comes with a little plastic scrapper. the first one turns the pinstrip or woodgrain decal into a raised bunch of goo, the second turns the adhesive into an oatmeal like consistency.
