Piranha props: interesting but need more info
watered down
Came across these Piranha composite props ...interesting concept. Anyone ever use them or know much about them? How do they compare to aluminum props in performance and reliability?<br /><br />Oh, and while I'm at it...anyone know where I can get one of those floating prop wrenchs for volvo?
walleyehed
Re: Piranha props: interesting but need more info
Pirana may run a bit (slight bit) better than stock aluminum in some cases, but you will spend some time replacing blade segments.<br />They do flex some too, and the one I've run showed it doesn't take much of a hit to shear a blade...infact, I don't think aluminum would have shown any damage in that particular case.<br />The solid composite hub tends to wear and eventually strip the splines out, if the blades out-last the hub that is....
maxxpower
I bought my prop online last winter and ran it <br /><br />all season without any problems. As far as <br /><br />performance, I had a stock aluminum on my 3.0 <br /><br />liter sterndrive and noticed no difference in <br /><br />performance, except smoother shifting because of<br /><br />its lighter weight. The company claims that the <br /><br />material is 15% stronger than aluminum. I bought <br /><br />one because I boat in shallow water. It would be <br /><br />cheaper to replace all three blades (about <br /><br />$60) than to have the prop reconditioned, and <br /><br />there is no down time. I would buy one again.
maxxpower
Walleyehed, I am not sure what size motor you <br /><br />ran your piranha on, but on the bigger motors the<br /><br />hub is made of ALUMINUM which is encased in the <br /><br />composite material. The hubs also have a <br /><br />lifetime warranty.
walleyehed
I ran 22 props for Piranha 3 years ago on my 115, and none of them hade any metal of any sort.<br />All 3 blade styles in 3 and 4 blade.<br />Only one prop strike with any of them, and the blade sheared without resistance...Believe it was the "B" style blade.
maxxpower
walleyehed, you may have Piranha props confused <br /><br />with another brand. Directly from the website:<br /><br />Piranha propellers'center hub uses a high grade <br /><br />6061 extruded aluminum core which is <br /><br />encapsulated in the same composite material as <br /><br />our propeller blades." Check it out on their <br /><br />website; www.piranhaprops.com/ :)
walleyehed
No, I ran these FOR Piranha. I dealt directly "with" them.<br />One of the problems we had was shearing splines...there was no material(at that time)in the hub, just the same composite structure as the blades, but as I look at the site, I see the warrantee on the hub, so They have up-graded their prop system, and it looks as though they have discontinued 1 of the 3 styles of blades they had when I ran them.<br />Good to see they are keeping up with designs and taking care of the original structure problems.<br />I may have to call and see if I can run a couple of the newer ones on my 200.
