I have a 90 Hp outboard Johnson, VJ90TLESB. One day I overheated my engine after my water pump failed. I replaced the water pump and the engine ran fine. About 2 trips later though, my engine ran sluggishly and rough, like a cylinder wasn't firing. I hooked up my compression tester and #1 cylinder had zero compression, #2 had 110 psi, #3 had 90 (with water in the cylinder), and #4 had 105 psi. So, I took of the starboard head since the problems were on that side. See the attached pictures. #1 piston has a lot of pitting and carbon buildup, while #3 cylinder and piston look fine. If I run my fingers around #1 cylinder, I can feel slight wavy grooves all the way around compared to #3 cylinder that feels smooth/flat. #1 piston also has noticable side to side play where #3 has not as much. So, I'm open to suggestions on what to do.
