I'm jumping into my first motor rebuild and need help selecting the correct piston.
The motor is a 2001 35hp Johnson.
I'm seeing aftermarket pistons only go up to 1998. However, comparing piston part numbers on Johnson's website, shows the 98 and 2001 having the same part number(#0437219). I'm assuming they are the same piston?
Which leads me to believe I'd be ok ordering from here part number 35-3111P2? From the sites part number I'm guessing those are Wiseco pistons?
