piston rings
qaztwo
when installing new rings in a marine engine are moly better then plain steel for use.
thanks
Re: piston rings
Piston Rings are Cast Iron,..........
I'd go with the Moly coated 1s.......
qaztwo
Re: piston rings
I thaught the same thing about the plain rings to. Moly's are supposed to last longer, but in marine applications does it matter.
calwldlif
Re: piston rings
There are different honing specs
for Moly rings. Make sure you tell you machinist the type rings you are using so he/she will put the right pattern
