Re: piston stop tool
Fichts use a "special" stop tool. It's used similar to the standard "old style" one that everyone is thinking about but it has a long plastic shank on it. If you are checking the top-dead center and have the computer to set timing, you've got to have a manual, NO ??? If you have a factory manual, you will see the proper tool and the method to use it correctly. You can not "time" the engine with just a timing light, you must have the computer and software to do so ! Hense, the need for the factory manual!!
