I have a 1995 Stratos 20ft. with a Johnson 175.
The boat came with a pitot tube for the speedo mounted on the bottom of the transom. However, the speedo has never worked since I got the boat, it's dead.
Since I've been looking into a new set of gauges I've learned that there is a fitting coming off my lower unit that is a pitot built into the lower unit of the motor.
Question - Which should I use? A new pitot installed where the old one was on the transom or come off the fitting on the lower unit? What are the differences and which one would be more accurate?
Thanks!
Thanks!
