I am getting ready to install a speedo in my MFG Carefree 14. How this insturment operates is pretty simple. Now my questions. The installation instructions say to mount the pickup assembley 6 inches to the starboard of the centerline of the boat. If i install the pickup in this location, it sure is going to make a bunch of twists and turns to get it up to the back of the insturment. I would like to hide the tubing under the starboard gunnel. This supplied tubing will not lend itself to a tight radious without kinking. Is their a problem with mounting the pickup close the the starboard side of the boat? This would make a much more direct routing (less turns) to the backside of the insturment. Are there some sort of 90 degree fittings to make this install look cleaner? Where you have to drill a hole thru the transom, :facepalm:, what angle should this hole be drilled at? The thought of drilling a hole thru your boat, well, what can i say.
. Please Advise. Mitch
