Last night while installing the new head gaskets on my Merc. 175, I noticed about 4 very small pits on the bottom side of the #5 cylinder wall. This is the same cylinder that was getting water into it that caused me to replace the gaskets.<br /><br />Anyway, 3 of them are barely noticeable, but one is about 1/16" in diameter and probably the same or less in depth. It's about a 1/2" exposed when the piston is at it's down stroke position. The other small pits are farther up (or nearer to the top of the cylinder head). <br /><br />Is this a major problem? The rest of the wall(s) look very clean and smooth...
