Placement of little collar on top of 125 HP lower unit drive shaft
pastorbud
I had my lower unit off my Force 125 hp,
Mod 1251X7B
Ser 3795
As I was trying to lift it up for re-installation, I managed to pull off the little collar that slips over the splines at the top of the vertical drive shaft.
Now I don't know which way it goes back on: Flat side up, or groove side up? See pix.
tater76
Re: Placement of little collar on top of 125 HP lower unit drive shaft
Groove up, it is actually for a rubber boot to fit in. However, don't worry, you don't have to have the boot. Just be sure to put alot of anti-seaze or grease on the splines before reinstallation. If you put it in dry it can get stuck easily.
jerryjerry05
Look up inside the rubber boot might still be in there.
If it is it can stop the drive from going all the way up.J
pastorbud
Thanks, guys. Almost put it in wrong. And I could not get the shaft in, so I'll check tomorrow for the above-noted little boot.
