Planing Problems
crazyboat1
I have a 95 Mariah 21ft with a 350 mag and an alfa 1 outdrive. From a stand still and giving all the throttle I can she wont plane for well over 15 seconds with only 2 people in the boat and a 1/2 tank of gas. I have tried 2 props and both give the same results, one 21 pitch and one 19 pitch. Once she planes out it gets up and goes to about 4800 RPM. Any ideas?
Tufan
Re: Planing Problems
I have the same boat... With 205 davanti / merc engine & alpha 1 I/O. I use 19 pitch SS prop, she planes out right away, did you try trim down?
crazyboat1
i have a Z 212 shabah! The trim is all the way down. Thanks for the input. I get the same results going from a 19 pitch SS and a 21 pitch aluminum.
Jdeagro
iboats.com Partner
Crazyboat1;<br /><br />You should notice a considerable difference between the 19 and21 pitch props. Call me - there is something else not right. 800-233-0194
