I've read many times on this forum that certain boat hulls do not plane off in the water. What makes a hull able to plane off? Does it require a certain amount of surface area contact with the water or just a sloping hull? If it is designed to float and move forward, then it will plane off. A pontoon boat will plane off if fast enough. The resistance of water is much greater than the resistance of air. Think of an airplane wing. It is the friction of air under the wing that builds pressure under the wing to lift the plane up. The friction of the water is pushing your boat upward. All boats have a sloped hull that allows water to push the boat upward. The hull can be flat as long as the front of the hull slopes upward. I’ve been told on this forum that my 14ft jon boat will not plane off. All I know is that at 15mph, I have a very large wake for a small boat. But when I gun it to about 20mph, I can actually feel the boat lift up out of the water and I then have a wake that is about 1/3 the size as before. The angle of the boat never changes. If that is not planing off then what is?
