Re: Plastic Drain Plug Replacement?
Bondo,<br /><br />I understand what you are talking about. I am not sure I want to go to the smaller draincocks. I did like the flow rate from the block with the whole plug removed. The water that drained into the bilge showed no sign of sand or scale. Even though I had a wire and poked it up the holes, no blockages were found. I did remove the two broken plastic drain plugs. <br /><br />Why the antifreeze? Just for the rust protection. The way I look at it, as long as I've drained the water correctly, I couldn't hurt things by using the Ban Frost 2000, and it might even help if I didn't completly drain. While the boat will be in a shed, it will still be subject to temp fluctuations and outside humidity and condensation. The Merc SM also recommends this for extended storage. May '05 seems like too far away, right now! Still hard to believe the season is over, for that boat anyway. Still have 3+ months of river fishing w/outboard. <br /><br />I didn't get a chance to stop at the dealer today. If the plastic plugs are cheap, might just get them, and have plenty of spares, for the next one I crack. <br /><br />BTW, I am not taking it lightly, when two marine experts recommend a drained block. That seems to be knawing at me, in the back of my head. It will be two weeks before heading back, to finish the winterization. Maybe I'll be convinced by that thought, by then.
