The number 1.,81 means nothing by itself.  Ratios are a relationship between two things.  In your case, engine rpm and propeller shaft rpm.  The proper expression in your example is 1.81:1.  This indicates the engine turns 1.81 times to make the prop shaft (hence the prop) 1 revolution.
