Please help 1967 Johnson 20hp
Joseph062
Hey, I am new to the whole 2stroke outboard thing. I recently purchased a 1967 Johnson 20 from a buddy for $200 he started it up and told me it was running rough and I could tell obviously. Figured I’d give it a try and clean the carb and do a few other things to try and get it running right. When I got it home I immediately realized it looks like there is a linkage missing from the rich-lean adjustment at least that’s what I think it is lol. Anyway is there a way I can still adjust it properly such as I don’t even know how to tell if it’s rich or lean right now. Any help would be amazing like I said I really don’t have a clue what I am doing but I’m trying I have experience working on small 4stroke engines but no outboards.
Crosbyman
just pull the engine cover and adjust the top needle manually … if it settles down forget about it or order a link for 6$
you can always rig one up with a piece of clothes hanger and clips of the proper size
lindy46
The part number for the arm is 308362. If you also need the valve arm, it is part number 204705 - pricey at $25 new. You can probably find a used one for a fraction of the cost.
Crosbyman
by the way… turn the engine upside down and shake it…. I found my link for a MQ 9.5 down the the pit… maybe the previuous owner dropped it down there
try TIM's outboard for used parts
rich = counter clockwise lean clockwise tighten down collar nut after adjusting
