Please help, 1990/1993 Evinrude V4 140 hose location
Josephmcg
Hey everyone, I am back getting the what I thought was a 1990, but turns out its has a 1993/1994 powerhead, 1990 mid and lower, Evinrude V4 140.
The problem is I am not sure where this hose goes, it is connected with the tell tale or the "pissing" tube where the cooling water exits the engine, I have attached pictures in hope that someone has the knowledge to pass onto me, thank you in advance.
I believe that hose does NOT go anywhere .------It just lays in the cowling !!
Josephmcg
Thank you so much for your reply, I was thinking that it may just hang out in the cowling because even in the parts diagram it doesn't show a location
Correct it is called a ---" Drain system "----Hence the notches on the end of the hose.-------Syphons water out of the lower cowling if it should ever become flooded.
Josephmcg
Awesome! That definitely makes sense, hence the one way valve in the end of that big hose. Thank you so much! I searched for so long for this answer
