please help 7.5 mercury
slate1234
Hi all i have a 7.5hp mercury 1976,I have renewed bouth wires to the points,plugs leads, plugs and all was fine but i run it and one of the wires from the points I ran the wroung way and the fly wheel cut it i replaced it now it wont start, I have reset the points time and again but nothing and to top it all someone has wiered it with diffrent coloured wireing so my manual is not a lot of help have a switch the wires go from the coil under thw stater plate I would be greatfull for any help Thanks Paul
M
Maxz695
Guest
Re: please help 7.5 mercury
May not help but be sure you put the wire on "TOP" of the insulator on the points. I have seen it done where someone put the connection to he points under the insulator on a motor cycle. I switch i aroun and it started righ up
slate1234
thanks maxz the wire goes through the back of the plastic block i will check my wiering tomorrow
Thanks Paul
M
Maxz695
Guest
Make sure your not on the ground side of the insulator but on the hot side where the nut is
slate1234
have i wired it correct the wireing from the points go to negative on the coil the wiering from +on both coils and condenser all to the same terminal on the stater and red wire from kill switch to the other terminal black goes to ground
slate1234
how to set the points correctly on 7.5 mercury
Hi guys could someone be so kind as to tell me how to set the points on a 7.5 mercury (1976) this is before i use this engine as my anchor lol being a builder and enjoy playing with engines but this thing has beat me I think also withch set of points for which cylinder ?? I got this cheap the guy before me has rewired it useing diffrent coulerd wires and I have rewired the points, I have two green wires from the coils to the stater and one green from the condenser to the same and a red wire from the kill switch to the other then wiers from the ponits to the negatives on coils if all that makes sense??
Any help would be appreciated :confused:
M
Maxz695
Guest
Re: how to set the points correctly on 7.5 mercury
if you did hook the points up visa versa the cylinders would fire on the wrong stroke and you would not be able to start it. The cam lifts and closes the points at the percise time the engine needs fire. Try switching the around. Set the flywheel at 0 Topdead center. Find which set of contact points is closed. That wire on those points would go to Number 1 cylinder coil.
slate1234
get the tools out tomorrow and try that thanks again for your intrest and help
Paul
