Ok, here is what I know or have done to the motor thus far:
Has good spark from both coils
Compression is good on both cylinders
Cleaned and rebuilt carbs
new fuel lines
still has VRO pump - oil disconnected and line plugged
replaced fuel primer solenoid (was blowing fuses)
The motor is running really rough, no power unless I hold in on the choke. It will run fine on muffs, idle all day long. As soon as I put it in the water, it dies, wont idle, and runs like crap. Would like to have some advice on what I should look for. I am lost!!!!
new fuel lines
