PLease help clogging fuel filter with whats left of the old gas
TrimmedOut
WELL FIRST OFF HELLO IM NEW TO THE BOARDS AND MY NAME IS JIMMY heres the long story short
~bought boat 1987 27' IMP merc 454
~sat for 3 years
~drained 80 gal of old gas out of her after i added 30+ gallons new ehhh
~took some fresh gas and sprayed the walls of the tank well the best i could through the sending unit hole and a small pump
~drained the rest of the crystleized icetea crap gas out of the tank through the pickup
~just got 40 gal fresh gas in there
~installed small inline clear fuel filter
~within 5 min of just ideling it clogs up with crystled garbage i definetly dont want to drain it again and waste another 100 dollars worth of gas what should i do
>get a bigger fuel filter if they even sell one and just run it for a day....
>keep what i got and clean it every 5 min till it clears up.....
>is there some additive i can put into the gas to disolve the garbage enough to pass through the filters w/o clogging them or ruining the motor?
Re: PLease help clogging fuel filter with whats left of the old gas
Ayuh,... Pull the Tank,+ have it Cleaned...
The gas that's in it now can be saved by pumping,+ settling...
kenmyfam
I have to agree. Removal and a thorough cleaning is the only sure way.
TrimmedOut
damm id figurerd that would be the answer....
removing the 90 gal tank is not as easy as u make it sound especially with the boat in the water, if I... which i dont want to again pump all the gas out is there a way i can clean the tank with something without removing it?
then how do i clean the gas to put it back in?
Ayuh,... You could call around for somebody who does "Fuel Polishing"...
Or,..
You could build a Fuel Polishing system,.. Small scale of course...
You'll need a Filter or 2,+ an electric fuelpump...
Basically, you keep pumping the fuel in a circle through the filters til the $h!t is Gone,+ the fuel,+ tank is CLEAN...
Home Cookin'
carb cleaner is good for cleaning the tank if you do it yourself.
