Re: Please help ID cable bracket
Thanks. After working on the engine last night, it finally dawned on me what this is. This Seadrive was converted to a conventional mounting bracket for top-of-the-transom mounting. (Does anyone know what's involved in a conversion like this?) Just wondering what was replaced to add this bracket.<br /><br />Anyway, the engine pan I have is exactly as you describe, SoLittle. Instead of the battery cables, harness, etc coming directly in front of the engine well away from the mechanical steering, they come out of the bottom of the engine such as yours does. The problem is that with the mounting bracket conversion, I need a "tie point" for the cables and harness in order to avoid rubbing on the steering link arm. This part is basically a clamp that must have been added on later to provide that tie point so the lines would clear everything by clamping them out of the way. I haven't used this motor yet so it's quite a discovery process.
<br /><br />SoLittle, do you have a grommet around that hole in the engine pan to prevent chafing the wires? I tried getting one at the dealer and they had no clue what I was talking about. I ended up cutting a leftover piece of fuel line down one side, and siliconing it to edge of the hole. There's still a bit of open space there so the only option I can think of is to silicone fill in between the wires to prevent water from coming in.<br /><br />Thanks again, SoLittle. Got any spare parts you wanna sell?
<br /><br />Regards,<br />Dennis
