Please help. Ignition question
Patriot70$$$
I have read some threads and can't seem to find the one I need. I have a 1990 force 90 on a 18ft bay liner Capri I just rehabbed I cannot find my keys for the ignition so I can't really see if the new accessories work. It has ten wires coming out of it can i find a replacement? Why are there ten wires? What kind of replacement ? Oem? Thanks russ
Frank Acampora
Re: Please help. Ignition question
The switch itself should only have six terminals whether or not it is Force or mercury ignition. a standard push to choke six terminal switch should swap right in.
There were only about 5 keys for the original switch so if you can find a number on it you can order a key. If you bring the switch to your Mercury dealer, they may have keys on hand to test fit--hey worth a try to ask.
Jiggz
If you haven't mess it up yet, you can just order all sets of keys and it will still cost you less than a new set of ignition switch. I forgot how much the key cost but they are dirt cheap. Or even better if you remember the number stamped on the key you lost, it makes it even easier.
jerryjerry05
10 wires??? Some are for ignition,some for the trim/tilt.another for the power to the dash/ignition.
You should have a wiring chart on the motor somewhere?
Blue/green is for trim.brown is for the t/t sender?
