please help me Main master power switch click every one minute
I got a 2007 hurricane boat fun deck on the main master power switch keep clicking every 1 minute , then i turn on the other switches for boat like raido , live bait well, and fish finder it still click, replay the main power swith and it still clicking every one minute. Even with a new switch, what could be the problem every 1 minute the with out having anything else on but the main power switch and just having that on causing a clicking noise and on the main dash i can,t see flashes red light , and after one minute only on the main master switch on it start clicking with out turn on the other switches, but on my 2007 fund deck i can,t turn on the other switches unless i turn on the master power swith so i don,t know what to do or try . I thanks all the reply to my post thank you so much.that the main power master switch that control all the other switches, you need to turn the main on to have the other switches working , i can turn all on and they all work but i get the clicking sound every one minute like it trying to turn off but everything runs ok, but it flases red that show the swithes are on but flash on the dash and make a clicking now and flases the red light. I hope i gave enuff info for someone to help me thanks inadvance for all to reply. thanks
clicking sounds like a auto reset breaker or a relay. You need to get under the console and find the item clicking then take a pic or describe what it looks like. If its a auto reset then you probably have a short to ground or a overload. (as its happening with just the master switch it probably a short).
GA_Boater
Crabby - You are setting records in iboats Forums. Records that don't need broken. You have posted this same topic 12 times! This is the only one with a response and the other eleven have been deleted.
If you need help using the Forum, just ask. Thanks.
