jejeosborne
- Sep 9, 2009
- 4
I am currently in search for our first family boat. One that has cought my eye is a 19' 1983 Century Sport XL 3000 open bow boat. This boat only has 330 hours and is in very good cosmetic condition. Had a compression test done and found all 8 cylinders to be between 100-125 psi. It has the mercruiser 260 5.7 liter engine. This boat is loaded with features such as a built in wine rack, cooler, new stainless prop and even a windshield wiper. Trailer is a nice tilting tandem also in very good condtion. I test ran the boat in the water and took it up to 45 MPH and it came out of the water quickly.
Now for the problem........ In the storage area on the starboard side, the floor was soft under the trim motor assembly. I proceed to poke around on the transom where the two meet and found a soft spot about 8" in diameter on the transom. The area around the engine is still solid and when bouncing on the lower unit I get no flexing. The other side and everywhere else is solid. It appears that this could be repaired without removing the engine and only removing the power stearing and trim motor.
I am pretty handy with construction and maintenance and don't mind a little elbow grease.
So.........Should I run like the wind and be scared or should I make buy it and make myself a winter weekend project? She has lowered the price to $2800 with the trailer. I am thinking the trailer, prop and engine is worth that?
Thanks for any help.
Jeff
Jeff
