Re: Please Help Me With My Alpha One
Ayuh,....
Did you have it in Forward when you took it apart,..??
Did you have it in Forward when you put it back together,..??
I'm Guessing you'll be answering,..... Nope...
If so,... That's the Problem.....
To fix it,.. Pull the lower back off, shift Everything into Forward,...And reinstall it...
It should Work then....
Btw,.. Just a little Trick,....
Wrap a bungee strap from the Cav-plate, around the prop shaft,+ back to the other side of the Cav-plate,..
Shift the lower unit into Forward,+ the bungee will hold enough tension on the prop shaft, so it Won't slip into neutral when you're putzing trying to get it remounted...
