gonefishin485
- Jun 29, 2008
- 108
so heres the deal, a while back i bought a 1978 115 evinrude V4, it runs but it has some "issues" it has good compression on all 4 cylinders, and a good hot spark on all 4 cylinders but...........
from a dead cold start, it will not crank on its own, i have to squirt a little gasoline in the front of the carbs to get it to crank, you can choke it, raise the fast idle lever, and cuss at it, it just will not crank on its own no matter what you do, unless you shoot a little gas in the carb throats
once i get it cranked and running on the ears, i cant bring the idle lever on the control box down all the way, or it will die, then will not crank back up on its own (see above)
i cant idle it up any, because the idle screw on the throttle/shift cam, is screwed all the way down, and i cant adjust the carbs, because they have no fuel air mix screws (call me a liar but ive looked the carbs over a 1000 times and cant find one)
i tried 2 different brand new attwood primer bulbs from walmart, neither would push gas into my carbs from my tank, and yes i had the fuel flow in the proper direction, tried my neighbors line and tank (trying to eliminate variables) and it did no different
the bulb never quite gets solid like its suppoesed to, always has a slight sponge to it, like theres air trapped somewhere
i did manage to take it out on the water once, with a 13 pitch prop (needs to be reproped) on a 17 foot glastron with 3 full grown adults, it reached 33mph and ran fine at WOT, but wont crank on its own or idle to save your life
someone help me, id like to go fishing
