Please help mercruiser 260
Jhayes780
So got a boat with a mercruiser 260.
Replaced the valve cover.
Went out on the water and at low rpm it was fine
Higher rpm it immediately smoked and overheated
Came back the next day and there was oil pooling in the bilge?
Any help would be much appreciated
Ayuh,.... The 260 hp 350 Chevy has been in production since bout the early '70s,....
You've gotta narrow it down a bit more than that,....
'n why would you replace only one valve cover,..??
overheat has nothing to do with the valve cover
on this new to you boat, did you do all the drive maintenance, cooling maintenance, fuel system maintenance, etc that the prior owners did not do?
flashback
If you bought a boat missing a valve cover you probably have a few more problems. Go thru it with a fine comb.
Jhayes780
Ok sorry wasn’t getting email updates.
Don’t know the year
It wasn’t missing it
Tan fine for first few trips and then was running fine at lower speed after about half throttle started to heat up. Yes all the other maintenance was done. Risers impeller etc.
go back to the maintenance if its heating up. you have a cooling system issue.
ROY WILLIAMS
did the engine head gasket ....
Don’t know the year
Ayuh,.... What vintage is the boat,..??..??
If it overheated, start at the impeller, 'n work out from there to find where the water problem is,....
To find the oil leak, ya just gotta Look,.....
