Please help on......... 1998 90 HP Mercury
ezt13
My 17' NITRO has a 1998 90 HP Mercury <br />and it shuts off everytime I put it into gear whether it's forward or reverse. It seems that when I put it into gear it idles down and shuts off. If I Idle it high then kick it in gear it takes of fine and runs great in high speed. Please advise I just got this boat and would appreciate any advise on what it is... <br /><br />Thanks<br />eli
merc16
Re: Please help on......... 1998 90 HP Mercury
ezt 13,<br /><br />this could be a number of problems could be the carb, too much load on the engine
POORBOY
Decarb then adjust your idle up to spec's worked for me on my 97 3 cyl 90 hp mer<br />on and 18 foot tracker,I just got a while back
Bob Kimber
Hi Ezt13,<br /><br />I have a 2000 model 90hp, my experience with that motor is that the mixture settings on the carbs are very sensitive. If the motor has been adjusted or setup while in a test tank it is almost aways set too lean to idle properly when in the water. Do as suggested by Poorboy and then carefully check your settings on the mixture screws, mine runs best at approx 1 3/8 turns out from lightly seated, even 1/8 of a turn has a big effect on running, it will go from an intermittent lean sneeze to a perfectly smooth steady idle with these changes. <br /><br />You can try just turning out the screws an 1/8 of a turn at a time just to see if there are any improvements. The clearance between the throttle cam and roller is also critical for good performance, but has no effect at idle or very low speed (up to approx 1200 rpm), this clearance varies between different model years and is done using the throttle stop adjusting screw to align marks on cam and roller then adjust clearance to spec. <br /><br />Once setup properly I find the motor runs very well with good strong performance right through it's rpm range.<br /><br />Bob
ezt13
I would like to thank you guys for your time regarding this matter. Thanks for the advise I will give it a shot and let you know what happens. <br /><br />Thanks Again<br />Eli
