Please help starter on my chrysler stopped retracting after removal.
I Got my lower unit rebuilt then put it back together yanked her and had it run in a drum for a while. Then decided to kill it then try to restart and snap the pull cord went in half. So I looked at it closley and there is some plastic pin or something under the starter that fits up in there and keeps pressure on the spring. after I tinkered with it I notice that it will not retract so I then took the starter off and noticed the pin that connects from a bolt to the hold pin at the botton of the starter and after I messed with that a bit it started retracting again. My big problem is every time I put the starter back on the motor it stops retracting but I can get it to work while off the motor! can someone please help.
foodfisher
Re: Please help starter on my chrysler stopped retracting after removal.
It's binding on something. Were there spacers not replaced during reinstallation, or legs bent?
bentle
Need the make, year and hp of yr motor please.
1970 Montgomery Ward 20hp model number vwb27020a
I got the starter taken apart today and there is one end of the spring bowed out. And its rubbing the inner tube which is preventing it from retracting.So now I need to0 repair the spring or find a suitable replacement. Oh yeah pn# for the spring is 901970
